rfern33
6 years agoCyclone V Errata: False Configuration Failure in Active Serial Multi-Device Configuration x1 Mode
Hi, I have a few 5CEFA2F23C8s some of which require me to perform the "False Configuration Failure in Active Serial Multi-Device Configuration x1 Mode" workaround as per "Cyclone V GX, GT, and E Dev...
YuanLi_S_Intel
6 years agoI dont understand. The CRC will be implemented by default during device programming. Thus, we no need to run that. It will be ran by default.
- rfern336 years ago
Right. Do you know if this CRC is performed when we program the Configuration IC (EPCQ16A) or when the FPGA enters User Mode?
I am trying to ensure that disabling the CONF_DONE error checking flag does not compromise any security measures.
