rfern33
6 years agoCyclone V Errata: False Configuration Failure in Active Serial Multi-Device Configuration x1 Mode
Hi, I have a few 5CEFA2F23C8s some of which require me to perform the "False Configuration Failure in Active Serial Multi-Device Configuration x1 Mode" workaround as per "Cyclone V GX, GT, and E Dev...
YuanLi_S_Intel
6 years agoHi Reuben,
This is only happening when the FPGA is using AS x1 Mode. Apologize that all the batches are affected by this. Thus there is no way to avoid from this.
Thank You.
