Cyclone 10 GX Dev Kit FPGA SYS Max 10 Programming Using USB
-What is the error message shown?
-Have you try with another USB Blaster?
-Also, try to check all the possibilities posted in the link below;
Aiman
- AAhsan4 years ago
Only 2 device available on device chain
(and these two are configuration max 10 and Cyclone GX 10 )
Have you try with another USB Blaster? Yes
Idea is we want to access EN_GROUP signal to control power sequence
Question (For Power Group) ; All Power Group are controlled by EN_GROUP Signals . those signals are connected with system max10 FPGA and not access able by configuration max 10. USB blaster also doesn't provide access to system max 10 for load new image. How can EN_GROUP1 signals be used to controller power sequence.
