PL-USB2-BLASTER
3 years agocustomer wants to confirm software license compatibility - QE0A4A1
Customer wants to confirm item# IP-JESD204B
" I am using an Intel IP core called JESD204B. This core is licensed and I'm trying to purchase the license from Mouser. The license is IP-JE...
ZH_Intel
3 years agoHi Neil,
Good day.
We have not heard from you for quite some time.
I wish to follow up with you on this Case.
Did you manage to generate the Assembler report?
From the report you can see similar view as below to see which is license or unlicensed:
Assembler report example
Based on the JESD204B Intel® FPGA IP User guide under chapter 2.1 Release information, you can see the ordering code for this IP is "IP-JESD204B". You may share the assembler report and User Guide to double confirm with your distributor.
JESD204B Release information
You may refer to below link for more information:
JESD204B Intel® FPGA IP User Guide - 2.1. Release Information
Hope this answer your question.
Thank you.
ZulsyafiqH_Intel
