customer wants to confirm software license compatibility - QE0A4A1
Hi Neil,
Good day.
Regarding to your question, I might not be able to direct if the license is the correct one or which license you require without looking at the project.
However I can suggest to you to apply an Intel 90-Day Evaluation License use with Quartus Pro/Standard (Free licensing trial).
Login to Intel® FPGA Self Service Licensing Center and request the Quartus evaluation free license here: https://licensing.intel.com/
1) Go to Sign up for Evaluation or Free licenses
2) Select Intel® FPGA EVALUATION-LIC
3) # of Seats is always 1
4) Check the T&C box
5) Add the required options
6) Click Get License button
Once you run your project compilation, Quartus will automatically create a assembler report, .asm.rpt file.
( The assembler report is located in <Project directory>/Output_files/<project_name>.asm.rpt.)
This report will show which IP license that you do not have, then you may proceed to select the IP to purchase.
You may refer to below KDB as your reference:
FPGA Knowledge Base Article ID: 000080459 - IP licensing
Hope this answer you question.
May I know if are you using Intel development kit?"
Thank you.
ZulsyafiqH_Intel
