anaza3
6 years agocreating aocx file from Quartus project
I compiled a kernel by OpenCL compiler and it generated the Quartus project as well. I edited some stuff in the Quartus project. But how can I generate the .aocx file now from the project?
HRZ
6 years agoYou cannot do that. OpenCL kernels can only be synthesized into a working aocx file using the standard compilation flow of "aoc". If you want to modify the generated RTL code, C/C++ HLS is probably a better option for you:
https://www.intel.com/content/www/us/en/software/programmable/quartus-prime/hls-compiler.html
- anaza36 years ago
Then what is the point of creating a Quartus project if I can't use it? Why wouldn't I be able to change the aoc and continue the flow as before?
Particularly right now I don't want to change the RTL but I want to use chip plan/design partition. Would that be possible?
