FLoac
6 years agoCreate call signals in Platform Designer to run IP block
I could compile and synthesize the counter example correctly with the HLS compiler. I also added my newly created IP to my existing design in Platform Designer. But how can I generate the call and re...
MEIYAN_L_Intel
6 years agoHi,
May I know what is the meaning of "call and and return signal" here?
Based on my understanding, "call and return signal" is transfer data or read data to the new IP block, am I right? If yes, you may need to connect avalon mm /avalon st/ conduit, the connection inside the Platform Designer is depend on your application.
For more information about avalon interface, you may need to refer the document as link below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/mnl_avalon_spec.pdf
