Could not solve the Error: Modelsim (vsim) is not on the path in HLS.
Hi @Anand ,
I have tried this method but unfortunately it did not work. I still got the same error. I have searched in forums and internet but could not find anything.
- AnandRaj_S_Intel7 years ago
HI,
The Error: Modelsim (vsim) is not on the path is related to environment variable. Which is used to check that we have Modelsim in our path.
I have below setting which is working fine.
PATH=C:\intelFPGA\18.1\modelsim_ase\win32aloem
VisualStudio=C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\bin
QUARTUS_ROOTDIR=C:\intelFPGA\18.1\quartus
Kindly retry by restarting the system also check if you have vsim.exe under C:\intelFPGA\18.1\modelsim_ase\win32aloem
Anand
Hi @SOZDO ,
Just checked init_hls.bat file but I find any clue. Also bat file is working from current directory and it set current directory as ROOTDIR.
I will work on it and update you soon.
Anand
