Confusion regarding Stratix 10 OpenCL compilation report
- 6 years ago
Yes, the numbers in "acl_quartus_report.txt" is the entire chip usage. I just did a comparison between the HTML report on Arria 10 and Stratix 10 and I think I now see what you mean. On Arria 10 reports, after place and routing, a new section is added to the summary tab of the report named " Quartus Fit Resource Utilization Summary" which has the post-place-and-route resource usage of the kernel alone. However, this does not exist in the report for Stratix 10.
Looking through the compilation files, it seems these numbers are extracted from the biggest "*.fit.rpt". There is a table called "Fitter Resource Utilization by Entity" in the file and the entity called "freeze_wrapper_inst" seems to refer to the whole dynamic partition that includes the OpenCL kernel instance and its interfaces to the BSP. The same table also exists in the compilation folder for Stratix 10, it is just that it is located in "build/output_files/". I believe the same entity in that report also refers to the dynamic partition of the design and its area usage should represent the post-place-and-route area usage of the kernel, which is what you are looking for.
Hi ,
Thanks for the discussions.
We will take a note about this on aligning view of S10 reports similar to the A10 reports.
Thanks and Regards
Anil
