fpgalearner
7 years agoCompiling an application on the Intel OpenCL SDK results in compile failed error please help!
I am using the OpenCL SDK vs 16.0 to compile an opencl application. The compilation process starts and crashes at the very end with a "Compiler Error, not able to generate hardware" message. The log ...
KhaiChein_Y_Intel
7 years agoHi fpgalearner,
This error message indicates insufficient memory. You have to verify that you have sufficient memory available to compile your design.
