Compiling an application on the Intel OpenCL SDK results in compile failed error please help!
Here are my system specs:-
Intel Core i7-7700@ 4.2GHz
Available RAM- 45GB
I do not see that there is a over utilization of memory, Funnily however the application got compiled some time later with a recompile but again I get similar error in some other applications as well. Looking for concrete solutions, please help :(
If the same kernel compiled fine another time but you ran into the same error again with another kernel, you are definitely running out of memory. Are you running multiple compilations in parallel? Try to watch or even log your applications' memory usage and see what is taking up your memory when the compilation crashes.
P.S. DE5-Net has compatible BSPs with Quartus v16.1 and also 18.0+; you can always try using the newer versions of the compiler which will be more stable.
