Compiler Error while compile for Intel fpga device on Intel Dev Cloud machine.
On Intel Dev Cloud, I could able to build my sample program for GPU (default_device_selector) and also able to run on GPU machine.
But if try to compile the vector-add sample program (vector-add) for FPGA hardware by using 'make hw -f Makefile.fpga' makefile command, getting error.
https://github.com/intel/BaseKit-code-samples/tree/master/DPC%2B%2BCompiler/vector-add
It seems FPGA device not able to find from my Dev Cloud login. I ran 'aocl diagnose' command and that failed. Attached build and aocl log here. I am working for ZOHO corp.
1 Reply
- EBERLAZARE_I_Intel
hi,
I did check the files, just to make sure have you tried reinstall using "aocl install"?
Can you check below discussion if it may help with your issue:
https://software.intel.com/en-us/forums/intel-devcloud/topic/840082
https://forums.intel.com/s/question/0D50P00004WHjKr/oneapi-on-devcloud-fails-on-building-for-fpgas?language=en_US
Let me know if you have further questions.
