DorianL
2 years agoCompiler error oneAPI 2024.2
Hi everyone, I just updated my version of oneAPI to 2024.2 with the Base Toolkit and I don't know if I'm the only one but even after downloading the FPGA Support Package I can't compile my code anym...
DorianL
2 years agoHi @Kevin_Xu_Intel ,
Thank you for your answer :
1. My OS is Ubuntu 20.04
2. Here is the output of the "printenv" command
SHELL=/bin/bash TBBROOT=/opt/intel/oneapi/tbb/2021.13/env/.. SESSION_MANAGER=local/user:@/tmp/.ICE-unix/1639,unix/user:/tmp/.ICE-unix/1639 QT_ACCESSIBILITY=1 COLORTERM=truecolor XDG_CONFIG_DIRS=/etc/xdg/xdg-ubuntu:/etc/xdg XDG_MENU_PREFIX=gnome- GNOME_DESKTOP_SESSION_ID=this-is-deprecated ONEAPI_ROOT=/opt/intel/oneapi PKG_CONFIG_PATH=/opt/intel/oneapi/vtune/2024.2/include/pkgconfig/lib64:/opt/intel/oneapi/tbb/2021.13/env/../lib/pkgconfig:/opt/intel/oneapi/mpi/2021.13/lib/pkgconfig:/opt/intel/oneapi/mkl/2024.2/lib/pkgconfig:/opt/intel/oneapi/ippcp/2021.12/lib/pkgconfig:/opt/intel/oneapi/dpl/2022.6/lib/pkgconfig:/opt/intel/oneapi/dnnl/2024.2/lib/pkgconfig:/opt/intel/oneapi/dal/2024.5/lib/pkgconfig:/opt/intel/oneapi/compiler/2024.2/lib/pkgconfig:/opt/intel/oneapi/ccl/2021.13/lib/pkgconfig/:/opt/intel/oneapi/advisor/2024.2/include/pkgconfig/lib64: GNOME_SHELL_SESSION_MODE=ubuntu SSH_AUTH_SOCK=/run/user/1000/keyring/ssh CCL_ROOT=/opt/intel/oneapi/ccl/2021.13 I_MPI_ROOT=/opt/intel/oneapi/mpi/2021.13 XMODIFIERS=@im=ibus DESKTOP_SESSION=ubuntu FI_PROVIDER_PATH=/opt/intel/oneapi/mpi/2021.13/opt/mpi/libfabric/lib/prov:/usr/lib/x86_64-linux-gnu/libfabric SSH_AGENT_PID=1601 DNNLROOT=/opt/intel/oneapi/dnnl/2024.2 DIAGUTIL_PATH=/opt/intel/oneapi/dpcpp-ct/2024.2/etc/dpct/sys_check/sys_check.sh:/opt/intel/oneapi/debugger/2024.2/etc/debugger/sys_check/sys_check.py:/opt/intel/oneapi/compiler/2024.2/etc/compiler/sys_check/sys_check.sh ADVISOR_2024_DIR=/opt/intel/oneapi/advisor/2024.2 GTK_MODULES=gail:atk-bridge PWD=/home/user CCL_CONFIGURATION=cpu_gpu_dpcpp LOGNAME=user XDG_SESSION_DESKTOP=ubuntu QSYS_ROOTDIR=/opt/intelFPGA_pro/23.1/qsys/bin DPL_ROOT=/opt/intel/oneapi/dpl/2022.6 XDG_SESSION_TYPE=x11 MANPATH=/opt/intel/oneapi/mpi/2021.13/share/man:/opt/intel/oneapi/debugger/2024.2/share/man:/opt/intel/oneapi/compiler/2024.2/share/man: GPG_AGENT_INFO=/run/user/1000/gnupg/S.gpg-agent:0:1 QUARTUS_ROOTDIR_OVERRIDE=/opt/intelFPGA_pro/23.1/quartus XAUTHORITY=/run/user/1000/gdm/Xauthority GJS_DEBUG_TOPICS=JS ERROR;JS LOG WINDOWPATH=2 HOME=/home/user USERNAME=user IM_CONFIG_PHASE=1 GDB_INFO=/opt/intel/oneapi/debugger/2024.2/share/info/ CCL_CONFIGURATION_PATH= LANG=fr_FR.UTF-8 LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36: XDG_CURRENT_DESKTOP=ubuntu:GNOME VTE_VERSION=6003 SETVARS_COMPLETED=1 APM=/opt/intel/oneapi/advisor/2024.2/perfmodels CMAKE_PREFIX_PATH=/opt/intel/oneapi/tbb/2021.13/env/..:/opt/intel/oneapi/mkl/2024.2/lib/cmake:/opt/intel/oneapi/ipp/2021.12/lib/cmake/ipp:/opt/intel/oneapi/dpl/2022.6/lib/cmake/oneDPL:/opt/intel/oneapi/dnnl/2024.2/lib/cmake:/opt/intel/oneapi/dal/2024.5:/opt/intel/oneapi/compiler/2024.2 GNOME_TERMINAL_SCREEN=/org/gnome/Terminal/screen/73641c1f_3637_4d02_b1b6_e43e9ee4808b INVOCATION_ID=4dfc70fc819a4c6b8199de4aad6eb293 MANAGERPID=1241 CMPLR_ROOT=/opt/intel/oneapi/compiler/2024.2 INFOPATH=/opt/intel/oneapi/debugger/2024.2/share/info GJS_DEBUG_OUTPUT=stderr IPPROOT=/opt/intel/oneapi/ipp/2021.12 IPP_TARGET_ARCH=intel64 LESSCLOSE=/usr/bin/lesspipe %s %s XDG_SESSION_CLASS=user PYTHONPATH=/opt/intel/oneapi/advisor/2024.2/pythonapi TERM=xterm-256color DALROOT=/opt/intel/oneapi/dal/2024.5 LESSOPEN=| /usr/bin/lesspipe %s USER=user LIBRARY_PATH=/opt/intel/oneapi/tbb/2021.13/env/../lib/intel64/gcc4.8:/opt/intel/oneapi/mpi/2021.13/lib:/opt/intel/oneapi/mkl/2024.2/lib/:/opt/intel/oneapi/ippcp/2021.12/lib/:/opt/intel/oneapi/ipp/2021.12/lib:/opt/intel/oneapi/dpl/2022.6/lib:/opt/intel/oneapi/dnnl/2024.2/lib:/opt/intel/oneapi/dal/2024.5/lib:/opt/intel/oneapi/compiler/2024.2/lib:/opt/intel/oneapi/ccl/2021.13/lib/ DAL_MAJOR_BINARY=2 GNOME_TERMINAL_SERVICE=:1.82 IPPCRYPTOROOT=/opt/intel/oneapi/ippcp/2021.12 DISPLAY=:0 QUARTUS_ROOTDIR=/opt/intelFPGA_pro/23.1/quartus IPPCP_TARGET_ARCH=intel64 SHLVL=1 VTUNE_PROFILER_2024_DIR=/opt/intel/oneapi/vtune/2024.2 QT_IM_MODULE=ibus OCL_ICD_FILENAMES=/opt/intel/oneapi/compiler/2024.2/lib/libintelocl.so LM_LICENSE_FILE=/opt/intelFPGA_pro/LR-177233_License.dat CLASSPATH=/opt/intel/oneapi/mpi/2021.13/share/java/mpi.jar INTELFPGAOCLSDKROOT=/opt/intelFPGA_pro/23.1/hld LD_LIBRARY_PATH=/opt/intel/oneapi/tbb/2021.13/env/../lib/intel64/gcc4.8:/opt/intel/oneapi/mpi/2021.13/opt/mpi/libfabric/lib:/opt/intel/oneapi/mpi/2021.13/lib:/opt/intel/oneapi/mkl/2024.2/lib:/opt/intel/oneapi/ippcp/2021.12/lib/:/opt/intel/oneapi/ipp/2021.12/lib:/opt/intel/oneapi/dpl/2022.6/lib:/opt/intel/oneapi/dnnl/2024.2/lib:/opt/intel/oneapi/debugger/2024.2/opt/debugger/lib:/opt/intel/oneapi/dal/2024.5/lib:/opt/intel/oneapi/compiler/2024.2/opt/compiler/lib:/opt/intel/oneapi/compiler/2024.2/lib:/opt/intel/oneapi/ccl/2021.13/lib/ VTUNE_PROFILER_DIR=/opt/intel/oneapi/vtune/2024.2 QROOT=/opt/intelFPGA_pro/23.1 XDG_RUNTIME_DIR=/run/user/1000 MKLROOT=/opt/intel/oneapi/mkl/2024.2 DAL_MINOR_BINARY=0 JOURNAL_STREAM=8:47110 XDG_DATA_DIRS=/usr/share/ubuntu:/usr/local/share/:/usr/share/:/var/lib/snapd/desktop NLSPATH=/opt/intel/oneapi/mkl/2024.2/share/locale/%l_%t/%N:/opt/intel/oneapi/compiler/2024.2/lib/compiler/locale/%l_%t/%N PATH=/opt/intel/oneapi/vtune/2024.2/bin64:/opt/intel/oneapi/mpi/2021.13/bin:/opt/intel/oneapi/mkl/2024.2/bin/:/opt/intel/oneapi/dpcpp-ct/2024.2/bin:/opt/intel/oneapi/dev-utilities/2024.2/bin:/opt/intel/oneapi/debugger/2024.2/opt/debugger/bin:/opt/intel/oneapi/compiler/2024.2/bin:/opt/intel/oneapi/advisor/2024.2/bin64:/opt/intelFPGA_pro/23.1/questa_fe/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/opt/intelFPGA_pro/23.1/quartus/bin:/opt/intelFPGA_pro/23.1/quartus/linux64:/opt/intelFPGA_pro/23.1/quartus/qsys/bin:/opt/intelFPGA_pro/23.1/quartus/sopc_builder/bin:/opt/intelFPGA_pro/23.1/questa_fse/bin:/opt/intelFPGA_pro/23.1/quartus/bin GDMSESSION=ubuntu INTEL_PYTHONHOME=/opt/intel/oneapi/debugger/2024.2/opt/debugger DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus CPATH=/opt/intel/oneapi/tbb/2021.13/env/../include:/opt/intel/oneapi/mpi/2021.13/include:/opt/intel/oneapi/mkl/2024.2/include:/opt/intel/oneapi/ippcp/2021.12/include:/opt/intel/oneapi/ipp/2021.12/include:/opt/intel/oneapi/dpl/2022.6/include:/opt/intel/oneapi/dpcpp-ct/2024.2/include:/opt/intel/oneapi/dnnl/2024.2/include:/opt/intel/oneapi/dev-utilities/2024.2/include:/opt/intel/oneapi/dal/2024.5/include/dal:/opt/intel/oneapi/ccl/2021.13/include _=/usr/bin/printenv
3. The command "aocl -diagnose" is not found on my system even after loading the oneAPI environment variables. Does it means that I don't have the FPGA compiler ?
Thank you !
DorianL
Kevin_Xu_Intel
2 years agoHi DorianL,
Yes, if aocl isn't recognized on your system after running the setvars script, that means the FPGA support package isn't correctly installed.
Because we separated the FPGA support package in 2024.2, we put together a installation guide:
Can your refer to this guide to see if the install is correct? If needed reinstall both oneAPI basekit and FPGA support package according to the guide?
-Kevin
