jimbook
3 years agoCompiler Error, not able to generate hardware
when I compile for D5005 by oneAPI, I meet some problem like these:
Error: Compiler Error, not able to generate hardware llvm-foreach: dpcpp: error: fpga compiler command failed with exit code 1 (use -v to see invocation)
and in quartuserr.tmp:
Traceback (most recent call last): File "/opt/intel/oneapi/intelpython/latest/lib/python3.9/runpy.py", line 197, in _run_module_as_main return _run_code(code, main_globals, None, File "/opt/intel/oneapi/intelpython/latest/lib/python3.9/runpy.py", line 87, in _run_code exec(code, run_globals) File "/tmp/fig_17_17_ndrange_func-f8c444-f58169/build/./tools/packager.pyz/__main__.py", line 28, in <module> File "<frozen zipimport>", line 259, in load_module File "/tmp/fig_17_17_ndrange_func-f8c444-f58169/build/./tools/packager.pyz/packager.py", line 35, in <module> File "<frozen zipimport>", line 259, in load_module File "/tmp/fig_17_17_ndrange_func-f8c444-f58169/build/./tools/packager.pyz/afu.py", line 33, in <module> File "<frozen zipimport>", line 259, in load_module File "/tmp/fig_17_17_ndrange_func-f8c444-f58169/build/./tools/packager.pyz/metadata/metadata.py", line 28, in <module> ModuleNotFoundError: No module named 'constants'
in quartus_sh_compile.log:
This is the run.sh script. ERROR: packager tool failed to run. Check installation. Aborting compilation!
I don't know why it happen and how to fix it.
- hareesh
i seen one more case with your name both same problems or different
and please give some more information about your issue means what time are facing issues
- hareesh
