messn036
5 years agoCompile Intel HLS project with CMake
Hello Intel Community,
I am having troubles with CMake using MVSC compiler directives when trying to compile with i++. I am compiling on Windows with Visual Studios 17 installed.
I am using the f...
BoonBengT_Altera
Moderator
5 years agoHi @messn036,
Thank you for posting in Intel community forum, hope all is well and apologies for the delayed in response.
Clarification on the following, quick check which HLS design example are you trying to compile?
Unfortunately I did not try this before and are not sure if it is possible to compile HLS code with cmake, and user guides that we have on interchange compiler here does not have cmake included.
However, upon some research I do found some example here which is integrating cmake with Intel HLS tools which can be try on.
Please do let me know if that helps to clarify.
Best Wishes
BB
