RYang28
7 years agoCompilation warning in GZip example in Intel FPGA SDK for OpenCL
Hi, Recently, I'm trying the Intel FPGA SDK for OpenCL on Arria 10 boards. When I compile the GZip example with default flags stated in the readme.html. I got the warning msg below: Compiling f...
MuhammadAr_U_Intel
Contributor
7 years agoHi,
I have tried compilation using Compiler version 18.1 build 222 and 19.1 build 240 I didn't see any Warning for timing violation, here is the command I used.
aoc device/gzip.cl -o bin_a10_hw/gzip.aocx -DVEC=16 -DENGINES=1 -board=a10gx -v
Arslan
- RYang287 years ago
Hi MUsman, I've tried to compile against the a10_ref bsp in the SDK, and got the same output as yours with no hold time violations. Then I think the problem may be related to the bsp provided by the board vendor. Thanks for the help.
