Compilation Failed For s10gx: Couldn't open hotspot.aocx.tmp: Permission denied Error: Can't save value into package file: 'pkg_editor value.txt set .acl.version value.txt' failed
Hello, SDesh12,
Was your issue resolved following HRZ's suggestion which is excluding "." in the path ?
If not, please let me know.
No. But changing the permissions to "Everyone" for that folder and all sub-folders cleared this error.
But now I'm getting a different error:
Error (37028): Cannot generate Atom Netlist File because family Stratix 10 is not installed
Error (37003): Can't generate Atom Netlist File for device family Stratix 10
Error (16546): Cannot load final database - ensure all earlier stages of the compiler have completed.
Error (17941): The design could not be loaded due to errors.
Error: design::import_design -file base.qdb -overwrite failed!
Error (23031): Evaluation of Tcl script c:/intelfpga_pro/19.1/quartus/common/tcl/internal/qatm_import_design.tcl unsuccessful
Error: Quartus Prime Compiler Database Interface was unsuccessful. 8 errors, 0 warnings
Error (23035): Tcl error:
Error (23031): Evaluation of Tcl script compile_script.tcl unsuccessful
Error: Quartus Prime Compiler Database Interface was unsuccessful. 2 errors, 0 warnings
Error: Compiler Error, not able to generate hardware
-I have installed the drivers successfully, still the compiler cannot recognize the S10 packages.
Any solutions? @HRZ
