Beniel_T
5 years agoCL_INVALID_KERNEL_NAME runtime error in while runing on devcloud FPGA node
I was able to compile and run the code in the emulator as well as was able to build for FPGA hardware. But when I tried to run the code in FPGA, till the kernel called, the host code worked. B...
ArunJ_Intel
5 years agoHi
Could you please confirm if you are using oneAPI devcloud or FPGA devcloud. Also share with us the qsub command that you are using to request compute node.
Arun Jose
- Beniel_T5 years ago
Hi @ArunJ_Intel,
I'm using intel Devcloud and I'm using job submit script containing bellow line, where the script contains 'make run' the hardware binary.
qsub -l nodes=1:fpga_runtime:ppn=2 -d . $script
also, I print the platform and the device, before launching the kernel in the code and I get the output as,
Platform name: Intel(R) FPGA SDK for OpenCL(TM) Device name: pac_a10 : Intel PAC Platform (pac_ee00000)
After this verbose, at the point I call the kernel, I get the error.
