asenjo
5 years agoCL_INVALID_BINARY when running fast_recompile example (from oneapi_cli)
I've followed the steps to compile the fast_recompile example that is available via oneapi_cli. I got this error when trying to run it:
u32284@s001-n081:~/code-samples/fast_recompile/build$...
- 5 years ago
Ok, looks like I have to be in the right node with the right FPGA. If I compile for the Arria10 I can run in a node with Arria, but if I compile for the Stratix10 (-DFPGA_BOARD=intel_s10sx_pac:pac_s10) I have to look for another node with the right FPGA:
u32284@s001-n081:~/code-samples/loop_unroll/ArriaBuild$ ./loop_unroll.fpga Input Array Size: 67108864 unroll_factor 1 kernel time : 242.849 ms Throughput for kernel with unroll_factor 1: 0.276 GFlops unroll_factor 2 kernel time : 122.319 ms Throughput for kernel with unroll_factor 2: 0.549 GFlops unroll_factor 4 kernel time : 63.950 ms Throughput for kernel with unroll_factor 4: 1.049 GFlops unroll_factor 8 kernel time : 39.567 ms Throughput for kernel with unroll_factor 8: 1.696 GFlops unroll_factor 16 kernel time : 37.500 ms Throughput for kernel with unroll_factor 16: 1.790 GFlops PASSED: The results are correct u32284@s001-n081:~/code-samples/loop_unroll/ArriaBuild$ cd .. u32284@s001-n081:~/code-samples/loop_unroll$ cd StratixBuild/ u32284@s001-n081:~/code-samples/loop_unroll/StratixBuild$ ls CMakeCache.txt cmake_install.cmake compile.sh.e726724 loop_unroll.fpga Makefile CMakeFiles compile.sh compile.sh.o726724 loop_unroll.prj src u32284@s001-n081:~/code-samples/loop_unroll/StratixBuild$ ./loop_unroll.fpga Input Array Size: 67108864 Caught a SYCL host exception: Native API failed. Native API returns: -42 (CL_INVALID_BINARY) -42 (CL_INVALID_BINARY) terminate called after throwing an instance of 'cl::sycl::runtime_error' what(): Native API failed. Native API returns: -42 (CL_INVALID_BINARY) -42 (CL_INVALID_BINARY) Aborted u32284@s001-n081:~/code-samples/loop_unroll/StratixBuild$Then, reading here: https://github.com/intel/FPGA-Devcloud/tree/master/main/Devcloud_Access_Instructions#devcloud-access-instructions
I found how I can request the right node. The problem now is that I'm not authorized:
u32284@login-2:~$ devcloud_login -b A10PAC You are already logged into node interactively. u32284@login-2:~$ devcloud_login -b A10PAC Invalid Entry. Valid development stack options are: 1.2 1.2.1 eg: devcloud_login -I A10PAC 1.2 u32284@login-2:~$ devcloud_login You are selecting an interactive compute server sesssion. Please consider using batch mode submission using devcloud_login -b to not tie up compute servers with idle sessions. See the help menu using devcloud_login -h for more details. What are you trying to use the Devcloud for? 1) Arria 10 PAC Compilation and Programming - RTL AFU, OpenCL 2) Arria 10 - OneAPI, OpenVINO 3) Stratix 10 PAC Compilation and Programming - RTL AFU, OpenCL 4) Compilation (Command Line) Only 5) Enter Specific Node Number Number: 3 running: qsub -q batch@v-qsvr-fpga -I -l nodes=s001-n189:ppn=2 qsub: submit error (Unauthorized Request MSG=group ACL is not satisfied: user u32284@login-2, queue batch)Any help?
Rafa.
ChithraJ_Intel
5 years agoHi Asenjo,
Thanks for reaching out to us.
As checking your query, we could find that you are using FPGA devcloud. So, we are moving this query to FPGA forum for a faster response.
Chithra J
