CL_INVALID_BINARY when running fast_recompile example (from oneapi_cli)
- 5 years ago
Ok, looks like I have to be in the right node with the right FPGA. If I compile for the Arria10 I can run in a node with Arria, but if I compile for the Stratix10 (-DFPGA_BOARD=intel_s10sx_pac:pac_s10) I have to look for another node with the right FPGA:
u32284@s001-n081:~/code-samples/loop_unroll/ArriaBuild$ ./loop_unroll.fpga Input Array Size: 67108864 unroll_factor 1 kernel time : 242.849 ms Throughput for kernel with unroll_factor 1: 0.276 GFlops unroll_factor 2 kernel time : 122.319 ms Throughput for kernel with unroll_factor 2: 0.549 GFlops unroll_factor 4 kernel time : 63.950 ms Throughput for kernel with unroll_factor 4: 1.049 GFlops unroll_factor 8 kernel time : 39.567 ms Throughput for kernel with unroll_factor 8: 1.696 GFlops unroll_factor 16 kernel time : 37.500 ms Throughput for kernel with unroll_factor 16: 1.790 GFlops PASSED: The results are correct u32284@s001-n081:~/code-samples/loop_unroll/ArriaBuild$ cd .. u32284@s001-n081:~/code-samples/loop_unroll$ cd StratixBuild/ u32284@s001-n081:~/code-samples/loop_unroll/StratixBuild$ ls CMakeCache.txt cmake_install.cmake compile.sh.e726724 loop_unroll.fpga Makefile CMakeFiles compile.sh compile.sh.o726724 loop_unroll.prj src u32284@s001-n081:~/code-samples/loop_unroll/StratixBuild$ ./loop_unroll.fpga Input Array Size: 67108864 Caught a SYCL host exception: Native API failed. Native API returns: -42 (CL_INVALID_BINARY) -42 (CL_INVALID_BINARY) terminate called after throwing an instance of 'cl::sycl::runtime_error' what(): Native API failed. Native API returns: -42 (CL_INVALID_BINARY) -42 (CL_INVALID_BINARY) Aborted u32284@s001-n081:~/code-samples/loop_unroll/StratixBuild$Then, reading here: https://github.com/intel/FPGA-Devcloud/tree/master/main/Devcloud_Access_Instructions#devcloud-access-instructions
I found how I can request the right node. The problem now is that I'm not authorized:
u32284@login-2:~$ devcloud_login -b A10PAC You are already logged into node interactively. u32284@login-2:~$ devcloud_login -b A10PAC Invalid Entry. Valid development stack options are: 1.2 1.2.1 eg: devcloud_login -I A10PAC 1.2 u32284@login-2:~$ devcloud_login You are selecting an interactive compute server sesssion. Please consider using batch mode submission using devcloud_login -b to not tie up compute servers with idle sessions. See the help menu using devcloud_login -h for more details. What are you trying to use the Devcloud for? 1) Arria 10 PAC Compilation and Programming - RTL AFU, OpenCL 2) Arria 10 - OneAPI, OpenVINO 3) Stratix 10 PAC Compilation and Programming - RTL AFU, OpenCL 4) Compilation (Command Line) Only 5) Enter Specific Node Number Number: 3 running: qsub -q batch@v-qsvr-fpga -I -l nodes=s001-n189:ppn=2 qsub: submit error (Unauthorized Request MSG=group ACL is not satisfied: user u32284@login-2, queue batch)Any help?
Rafa.
Any help?
Rafa.
