HYl
6 years agochange the frequency(uClk_usr uClk_usrDiv2)
I am working with Acceleration Stack Version 1.1 . How to change the frequency(uClk_usr uClk_usrDiv2) on the board? Does the uClk_userDiv2 have to be at half of uClk_user? I want uClk_usr to be 300M,...
JohnT_Altera
6 years agoHi,
You may get the older version of document from https://www.intel.com/content/dam/altera-www/global/en_US/others/solutions/acceleration-hub/ias-v1-1-pv.zip. Then please open ug-afu-dev-v1-1.pdf chapter 4.3.2.1.7 Specify User Clock Timing. The method to make the changes is almost the same with the version 1.2 has more improvement.
- HYl6 years ago
Hi, I already have done the necessary work according to ug-afu-dev-v1-1. I finally get .gbs,but i find the real uClk_usrDiv2 period is not correct.I find uClk_usr is 300MHz,while uClk_usrDiv2 is 150M ,not 100MHz.
