SAbde7
6 years agoCan't run DSE II on a high performance computer.
I am connecting to a university high performance computer through Putty. The computer has Quartus 19.1 installed. After opening my project in Quartus, I launch the design space explorer. I set it up ...
KennyT_altera
6 years agoCan help to answer the below?
1) Are you using Quartus standard edition of Pro edition?
2) Does the full compilation pass in a standalone design?
3) Can you attached your design.qar files to look into it? It might be a bugs.
SAbde7
6 years ago1)Standard
2)If you mean a standard compilation in Quartus, I just tried, it doesn't work. It also generates the "cpu: failed to generate module..." error
3) I'm not sure what .qar files do and am not familiar with them. I have not generated one myself but I am attaching the .quar file that I found in the dse folder
