Can't run DSE II on a high performance computer.
Can help to answer the below?
1) Are you using Quartus standard edition of Pro edition?
2) Does the full compilation pass in a standalone design?
3) Can you attached your design.qar files to look into it? It might be a bugs.
- SAbde76 years ago
1)Standard
2)If you mean a standard compilation in Quartus, I just tried, it doesn't work. It also generates the "cpu: failed to generate module..." error
3) I'm not sure what .qar files do and am not familiar with them. I have not generated one myself but I am attaching the .quar file that I found in the dse folder
- SAbde76 years ago
It might also be relevant to add that the project was initially created in Quartus 18.1. Also, after I open the project in Quartus 19.1 on the university computer and fail to compile there, when I reopen it again in Quartus 18.1 on my local machine and run DSE II, DSE II stays stuck setting up the compilation forever. The only way I found to fix this is restoring my project from a backup made efore I opened it in Qaurtus 19.1
