murrtank
3 years agoCan't find board.xml file
Hi again forum! I have some problem compiling to the fpga. When i try to run the compile I get this error
Error: No board_spec.xml found for board '/opt/intel/oneapi/intel_a10gx_pac:pac_a10' (Sea...
BoonBengT_Altera
Moderator
3 years agoHi @murrtank,
Apologies for the delayed in response, based on the command it seems that you are trying to build a OpenCL project. Are those steps running in Intel DevCloud or your local environment?
Would suggest to look into the following example which consist of details steps to build and run example design for A10 PAC devices:
Hope that clarify.
Best Wishes
BB
