Cannot view HTML GUI reports
What do you see when you open the HTML file? Do you see anything at all?
Also, how are you opening the report file? If you just copy the HTML file to another machine and try to open it, it won't work. You need to either open the HTML file using a browser on the same machine the report is generated on, or copy the whole report folder to another machine and open it there.
Yes, I am opening it on the same machine that generated the "reports" folder
This is what I see when I open "reports.html" (screenshot attached)
Clicking on the tabs that you see don't help.
- HRZ6 years ago
What is that browser which you are using? It seems to me that your browser might be incompatible with the HTML report, or maybe some addon you have installed is interfering with the report. Try with a standard browser like Firefox or Chrome and make sure java script is enabled is enabled in your browser and is not blocked by any addons.
- udishaduttachowdhury6 years ago
I'm using Chrome.
The issue still seems to persist. Is there any other way of generating the report? I am mainly looking for the loop and area analysis for my code.
- HRZ6 years ago
@udishaduttachowdhury Can you archive the "report" folder from one of your compiles and post it here? I can check on my side to see if there is something wrong with your report to at least rule out browser/system-specific issues.
