sThei
7 years agoCannot run HLS Compile example "counter"
Hi, I've got a similar error like here: https://forums.intel.com/s/question/0D50P00003yyTceSAE/intel-hls-can-not-generate-execution-file? I tried to run the example "counter": cd C:\intelFPGA_pro...
sThei
7 years agoHi again,
I'm using the correct command promt but realized that my VS2015 installations seems to be incorrect. The command promt now shows "ERROR: Cannot determine the location of the VS installation." (which ist strange, because the 2015 command promt is there).
I'll take care about that problem and let you know the result.
Thanks again :)
