sThei
7 years agoCannot run HLS Compile example "counter"
Hi, I've got a similar error like here: https://forums.intel.com/s/question/0D50P00003yyTceSAE/intel-hls-can-not-generate-execution-file? I tried to run the example "counter": cd C:\intelFPGA_pro...
Prince_J_Intel
7 years agoi am able to reproduce the issue. See the attached image which shows same error of LNK1107. This is because you are not using the command prompt i suggested. This leads to not recoginizing the correct visual studio libraries. see the blue encircled name of the command window.
Use below window instead. You can see that all works greats with no issues.
sThei
7 years agoHi again,
I'm using the correct command promt but realized that my VS2015 installations seems to be incorrect. The command promt now shows "ERROR: Cannot determine the location of the VS installation." (which ist strange, because the 2015 command promt is there).
I'll take care about that problem and let you know the result.
Thanks again :)
