cannot program the intel PAC with the provided hello-world bitstream **ERROR**: Interface ID check failed
Once server power on, the static region is loaded and PR region is empty I think.
Without loading gbs file into PR region, my server has no any issue no matter how long it runs.
Now I can successfully run many examples like I mentioned before without issue.
I can download different gbs files into PR region and perform tests.
If you are facing common BMC issue, you would see it through all other examples.
You can check if your version of FME and BMC is following the requirement in user guide, also you can check if your serer is validated or not based on user guide.
you might start to run nlb_mode_3 and dma_afu mentioned in the document Intel Acceleration Stack Quick Start.pdf.
different example draw different current loading, you might see different result.
I am still learning it, and still got so many other technical issues to solve, you can find my question in this field, hope my feedback can give you some idear.
Good luck
Jim
