MEghb
6 years agocannot program the intel PAC with the provided hello-world bitstream **ERROR**: Interface ID check failed
I installed the Intel PAC recently and I followed the instructions to install the drivers. Now, when I wanted to initialize the bsp with hello_world.aocx I will get the following errors: aocl progra...
MEghb
6 years agoThanks, It could be case with BMC since it is a normal workstation and it may be over heated by the FPGA. The only doubt I have is that, if its because of BMC, why the problem could be fix temporary by shutting down the system and start immediately, but it could not be fixed by rebooting the system.
Is there any other way, I could check to make sure that the problem is from BMC ?
( also my board is the same PAC aria10gx)
Mostafa,
