MEghb
6 years agocannot program the intel PAC with the provided hello-world bitstream **ERROR**: Interface ID check failed
I installed the Intel PAC recently and I followed the instructions to install the drivers. Now, when I wanted to initialize the bsp with hello_world.aocx I will get the following errors: aocl progra...
User1582192733150209
6 years agoI am using centos7 and Inatel PAC aria10gx.
I have expericed several times losting PAC in system, you can just input fpgainfo fme,and if there was no FPGA card information come out, you might know server lost fpga card for some reason.
one time was I downloaded a sof file through the signaltap, which is not supposed to do in that way, and I lost fpga and server restarted automatically,after system on,PAC card came back as normal as usual.
If you card can work for several minutes and lost recongnition, I think might caused by BMC ,which is used to monitor the current loading,temperature and some working parametters ,if some paratetters vaolated the limitation,BMS will shut the FPGA card from futher damaging.
