MEghb
6 years agocannot program the intel PAC with the provided hello-world bitstream **ERROR**: Interface ID check failed
I installed the Intel PAC recently and I followed the instructions to install the drivers. Now, when I wanted to initialize the bsp with hello_world.aocx I will get the following errors: aocl progra...
MEghb
6 years agoThanks for your response Jim. I was able to fix the issue by updating the firmware. However, the new issue I faced is that, I can run the opencl hello world example on the fpga and it worked fine but after couple of minutes (after I started the machine), the machine cannot recognize the fpga anymore, unless I power off the system and start it again. Is there any chance that you faced the same issue before, that your system only recognize your Card for couple of minutes at the beginning and not after that?
Also, I'm using Ubuntu 18.04 LTS. Please let me know if any other information could be useful.
Mostafa,
