RN1
4 years agoCannot compile with Stratix10 in DevCloud and Attributes-Local Memory Performance
==== First part) Stratix10 ====
We tried different ways without luck, therefore, we attach the same steps using the interactive session in a fpga_compile machine. We tried directly with you...
BoonBengT_Altera
Moderator
4 years agoHi @RN1,
Thanks for getting back that the compilation on the correct node in Devcloud.
As for the performance, we are looking into it as we speak and will get back to you.
Clarification if I may, above code are the dpcpp code, where are the openCL example which you are referring to? Just so that we are comparing the right things from our end.
Hope to hear from you soon.
Best Wishes
BB
