Can you analyze the bitstream icpx builds in Quartus?
The icpx tool can use Quartus to synthesize a bitstream which you can load on an FPGA. While doing so it produces some html reports. But those are pre-synthesis and often not enough to analyze performance issues. So I wonder if there is some way to load the files icpx into Quartus so you can analyze the project there? I've looked for documentation but not found anything about this.
- Jessica_Intel
Hi @Hoolabandoola,
The icpx tool can run Quartus, if you use the "FPGA Hardware Image" compilation flow documented here:
In that case, the html reports will be updated with post-Quartus resource utilization and clock frequency information, as described here:
I hope this helps!
Jessica
- Hoolabandoola
I'm aware of the html reports. However, they aren't very informative when it comes to post synthesis issues. For example, I have an OpenCL kernel that causes Quartus to run out of resources while synthesizing and I would like to know why.
