wgshnyhlw
3 years agoCan not find device after server carry two Arria 10 GX PAC.
Hi everyone,
I want to try to use two Acceleration card with Arria 10 GX FPGA, so that our system can deal with larger amounts of data in parallel. Everything works well before I plug in the seco...
JohnT_Altera
3 years agoHi,
I observed that when you grep the OPAE driver, you only have 2 driver installed. Below is the example that you should observed when installing the OPAE correctly.
wgshnyhlw
3 years agoHi,
I know the opae driver not fully be installed. Beacause before I use two PAC card, the opae driver installed correctly, which shows same with your picture.
So I want to know what happened with the driver after I use two PAC cards. It is strange because I think the driver should automatically detect when I plug in an new card. However the driver seems didn't look like what I thought.
I have been tried to reinstall the opae driver, but still not helpful, do you have other suggestion?
