User1582192733150209
6 years agoCan arguments of pac_hssi_e10.c cover all settings in design example eth_e2e_e10?
Hello Sir/Madam, To run design example eth_e2e_e10, we can use pac_hssi_e10 with some argument to configure part of the parameters, but not all of them. We can assign below value in design example ...
JohnT_Altera
6 years agoHi,
This parameter is being connected to the Address decoder in the RTL which will be control by the CSR register that CCIP will be able to control it. We have only enable certain function to work on the reference design as it is what it is implemented. You may check on "ccip_std_afu.sv" on how the CSR is being set and check on "Address Decoder" module on how it is mapped to the ethernet IP.
