student1
5 years agoC++ for FPGA
Can I write a program in C++, compile using DPC++ compiler generate bit stream using the add on toolkit and offload it to an FPGA. My question is ,can the source code be in C++ or should it onl...
BoonBengT_Altera
Moderator
5 years agoHi @student1,
Thank you for posting in Intel community forum and hope all is well.
Per my understanding, I would say yes you would be able to compile C++ code with DPC++ compiler, as it was build based on C++.
However for best performance on specific accelerators, there might be a specific tuning required in the code to allow that. (More details on the cross performance architecture can be found here)
Note: here are also some good references for the supported/required utilities for OneAPI.
Best Wishes
BB
