LSolis
7 years agoBuilding OpenCL kernel with v18.1.0 fails
Hi, I am using Intel FPGA OpenCL SDK Version 18.1.0 Build 222 Pro Edition. My problem is that building FPGA binaries fails, althought I used to build successfully the very same design with previous ...
LSolis
7 years agoBtw @HRZ , any suggestion on how to notify a moderator about this (if possible)?
- HRZ7 years ago
It seems the forum has the possibility of sending messages to other users. I haven't tried but you can try sending a message to one of the moderators who are more active in this section of the forum. However, if 18.0 works for you, you might as well go with that for the time being; there have hardly been any major improvements between the recent versions of the OpenCL compiler anyway.
