LSolis
7 years agoBuilding OpenCL kernel with v18.1.0 fails
Hi, I am using Intel FPGA OpenCL SDK Version 18.1.0 Build 222 Pro Edition. My problem is that building FPGA binaries fails, althought I used to build successfully the very same design with previous ...
HRZ
7 years agoYour kernel compilation is crashing due to some bug in the OpenCL compiler; this has nothing to do with the BSP you are using since the process does not even reach the placement and routing stage. You can try installing the 18.1.1 update and see if it fixes your problem. If not, based on your tests that the same kernel works fine in the older versions of the compiler, this is likely a regression in the newer version(s). If that is the case, then you will probably have to wait until some moderator in the forum escalates the problem to the engineering team.
