Building Card Image in FPGA AI Suite - missing CMakeLists.txt for hps_packages/protobuf/cmake
Hello, I'm working through the FPGA AI Suite Handbook 2026.1.1 and have got to the section where it builds the image with create_hps_image.sh, for example ./create_hps_image.sh -f $COREDLA_WORK/a10_perf_bitstream/hw/output_files -o jss10 -u -m arria10
It bulilds a fair bit but then falls over on making protobuf
cmake -G Ninja -B /home/ee05/coredla_work/runtime/hps_packages/protobuf/cmake/build_Release -Dprotobuf_BUILD_TESTS=OFF -Dprotobuf_BUILD_EXAMPLES=OFF -Dprotobuf_WITH_ZLIB=OFF -DCMAKE_POSITION_INDEPENDENT_CODE=ON -DCMAKE_INSTALL_PREFIX=/home/ee05/coredla_work/runtime/hps_packages/armcpu_package/protobuf -DCMAKE_TOOLCHAIN_FILE=/home/ee05/coredla_work/runtime/embedded_arm_sdk/cmake/embedded.arm.cmake -DCMAKE_BUILD_TYPE=Release -DCMAKE_EXPORT_NO_PACKAGE_REGISTRY=ON .
CMake Error: The source directory "/home/ee05/coredla_work/runtime/hps_packages/protobuf/cmake" does not appear to contain CMakeLists.txt.
At first the complaint was protobuf wasn't installed so I installed it with
sudo apt-get install -y protobuf-compiler
and it then got to error above.
Should there be a CMakeLists.txt in protobuf/cmake? Have I missed a step somewhere? here should the CMakeLists.txt come from?
Any suggestions greatfully received.
Best wishes, Jeremy
P.S. I'm on Ubuntu 24.04
I completly deleted the work directory and re did eeverything and it is now working. I can only think that the problem was caused by protobuf not being installed at the dla_build_example_design.py stage.
