NoahHuguenin
1 year agoAssertion failed in "hdl.cpp" when compiling HLS design
Good day! I'm working with Quartus Prime Pro 24.2 and its corresponding version of HLS Compiler. I get the following error message shortly after launching compilation, with an Agilex 7 board as...
Jessica_Intel
1 year agoHi Noah,
Thank you for posting your question. You are seeing an assertion failure in the compiler. I checked the release notes, and confirmed that this is not a known issue. Unfortunately I can't suggest a workaround without more information. I don't see anything incorrect about the code you shared.
Are you able to create a simpler version of your design that reproduces the problem?
I am also curious how cfixed_t is defined?
Jessica
