TLeng2
7 years agoArria 10 Dev Kit, adjust OpenCL BSP a10soc2ddr to use only the FPGA Memory..
I have a A10 Board with 2GB Memory for the HPS and 4GB Memory attached to the emif side of the FPGA, I want to get the Opencl system up and running without the shared memory stuff. ( boardtest.cl for...
TLeng2
7 years agoThank You for the Answer,
I worked the way through all these documents.
The Goal is to have the OpenCL working in the FPGA with the connected 4GB FPGA Memory, and the HPS working with its connected 2GB Memory. I made the proper changes in the Files and i got it up and running... unfortunately even without shared memory the Driver accesses only the host memory at the test which is weird. Also the aocl Program doesnt work with the actual linux kernels because the bridges are enumerated differently now. ( see my question about updated drivers and libraries. ) so it is compiling but partially working........
