NSriv2
7 years agoAre DRAM accesses in the opencl code for FPGA executed in a non-blocking manner?
When we access memory in the opencl kernel like this: for (int i = 0; i < N; i++)
... = A[i] Are they executed in non-blocking manner? Meaning does the generated FSM wait for the memory load to...
HRZ
7 years agoIn case of Single Work-item kernels, loops are pipelined. This also applies to the memory accesses inside loops. Hence, access requests are sent back to back and after a certain delay, data is received in the same order. If the buffer between the kernel and memory becomes empty, then the kernel will stall waiting for new data to arrive.
