Krus83
4 years agoaocl-clang.exe - Entry Point Not Found
Hi, I've been using the i++ compiler for a while now without issues but out of nowhere I'm getting an error when compiling, see below. Even after re-installing Quartus/HLS, the issue remains.
BoonBengT_Altera
Moderator
4 years agoHi @Krus83,
Noted with thanks on the details, my guess is there might be some corruption on your PATH environment variable, maybe you can double check on that.
As mention it was working previously, by any chances did you installed another version of quartus recently?
And the current in used or working previously are quartus 18.1 lite?
Hope to hear from you soon.
Best Wishes
BB
- Krus834 years ago
Hi, thank you for the fast response.
All paths have been checked and compared with a working system and I can't see anything wrong there.No other versions of Quartus have been installed recently.
Correct, 18.1 Lite is the one in use and was previously working.
Thanks in advance.
