RJimé1
6 years agoaoc: Quartus is not on the path! - Devcloud
Hello, I have suddenly come across the error aoc: Quartus is not on the path! on DevCloud when I was trying to compile a kernel with aoc. I was doing so from a node that is supposed to have Quartus,...
MEIYAN_L_Intel
6 years agoHi,
According to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/opencl-sdk/aocl_getting_started.pdf in chapter 1.1.1 stated that you can use older version BSP in newer Intel OpenCL compiler. It is not possible to use newer BSP with older Intel OpenCL compiler.
RJimé1
6 years agoOk, thank you. It seems I have to make my design work with the new version of the compiler.
