RJimé1
6 years agoaoc: Quartus is not on the path! - Devcloud
Hello, I have suddenly come across the error aoc: Quartus is not on the path! on DevCloud when I was trying to compile a kernel with aoc. I was doing so from a node that is supposed to have Quartus,...
MEIYAN_L_Intel
6 years agoHi,
According to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/opencl-sdk/aocl_getting_started.pdf in chapter 1.1.1 stated that you can use older version BSP in newer Intel OpenCL compiler. It is not possible to use newer BSP with older Intel OpenCL compiler.
- RJimé16 years ago
Ok, thank you. It seems I have to make my design work with the new version of the compiler.
