RJimé1
6 years agoaoc: Quartus is not on the path! - Devcloud
Hello, I have suddenly come across the error aoc: Quartus is not on the path! on DevCloud when I was trying to compile a kernel with aoc. I was doing so from a node that is supposed to have Quartus,...
RJimé1
6 years agoHello again,
As I stated in my last post, I am now capable of compiling kernels with AOC 20.1 and everything works like a charm. However, I still need to use the old version (19.3) of the compiler because my solution was designed around it. I thought it would be as simple as using the aoc binary located at /glob/development-tools/versions/intelFPGA_pro/19.3/hld/bin/, but, although the compilation completes successfully I get the error CL_INVALID_BINARY (-42) in OpenCL. Can you help me with that?
