Kulkarni__Vinay's avatar
Kulkarni__Vinay
7 years ago
aoc error for emulation
I installed opencl intel fpga sdk 19.2 and after installation the hello world example seems to compile smoothly taking default board as Arria10GX. But when i try giving the emulator compilation, i get following error:
My Machine spec:
Xeon-16 cores,32 GB RAM and Ubuntu 18.04.
aoc -march=emulator -fast-emulator -v device/hello_world.cl -o bin/hello_world.aocx
Warning: Command has been deprecated. The Fast Emulator is the default emulator; use -legacy-emulator if you wish to target the Legacy Emulator.
Error: aoc: The Intel(R) Kernel Builder for OpenCL(TM) compiler (ioc64) can not be found
Any idea on how i can fix this.
  • Vinay,
    Please, check that you set the environment variable CL_CONTEXT_EMULATOR_DEVICE_INTELFPGA=<number_of_devices>.
    For more information about emulating OpenCL Kernels read here.
    Sergey
  • Hello Vinay,
    Sorry for delay in answer.
    In previous version of aoc you should use "-march=emulator and -fast-emulator".
    In 19.2 version, please, use "-march=emulator -legacy-emulator".
    I guess, documentation of aoc was not updated to 19.2.
    Sergey
  • Hello Intel Folks,
    May i request you to please suggest solution for me. I need emulator urgently for my development.
  • Thanks Sergey for your help.
    Now i am able to compile, but running gives error as below:
    ERROR: CL_DEVICE_NOT_FOUND
    Query for number of devices failed
    Please let me know how i can get this working.
    My Runs are as below :
    (base) wc@ign:~/Documents/opencl_fpga/exm_opencl_hello_world_x64_linux/hello_world$ aoc -march=emulator -legacy-emulator -board=a10gx device/hello_world.cl -o bin/hello_world.aocx
    aoc: Running OpenCL parser....
    aoc: OpenCL parser completed successfully.
    aoc: Linking Object files....
    aoc: Compiling for Emulation ....
    ------------------------------Make of hello world --------------------------------------------------------------------------------------
    (base) wc@ign:~/Documents/opencl_fpga/exm_opencl_hello_world_x64_linux/hello_world$ make
    ../common/src/AOCLUtils/opencl.cpp: In function ‘_cl_program* aocl_utils::createProgramFromBinary(cl_context, const char*, _cl_device_id* const*, unsigned int)’:
    ../common/src/AOCLUtils/opencl.cpp:388:22: warning: ignoring attributes on template argument ‘cl_int {aka int}’ [-Wignored-attributes]
    scoped_array<cl_int> binary_status(num_devices);
    ------------------------------Running hello world ---------------------------------------------------------------------
    (base) wc@ign:~/Documents/opencl_fpga/exm_opencl_hello_world_x64_linux/hello_world$ bin/host
    Querying platform for info:
    CL_PLATFORM_NAME = Intel(R) FPGA SDK for OpenCL(TM)
    CL_PLATFORM_VENDOR = Intel(R) Corporation
    CL_PLATFORM_VERSION = OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 19.2
  • Vinay,
    Sergey
  • HMaha5's avatar
    HMaha5
    Hi Sergey,
    I work in Vinay's team. I was trying out the Sobel Filter Design Example. While compiling the host code I got this error
    host/src/display.cpp:23:10: fatal error: SDL2/SDL.h: No such file or directory
    #include <SDL2/SDL.h>
    compilation terminated.
    Makefile:74: recipe for target 'bin/host' failed
    make: *** [bin/host] Error 1
    Please help me to solve this.
    Thanks and regards,
    Hamsika.
  • Hi Hamsika,
    Sorry for delay.
    Could you please check that you have libsdl2-dev on your machine?
    If not, you can install it by executing this command:
    sudo apt-get install libsdl2-dev
