AI Suite - Spatial IP outputs wrong value
- 4 months ago
Have you tested on using the system-console to run the application? https://docs.altera.com/r/docs/863373/2026.1.1/fpga-ai-suite-handbook/running-the-hostless-ddr-free-fpga-ai-suite-spatial-ip-design-example
Can you guide us on how do you generate the Spatial IP? Please provide the full step so that we can duplicate the issue
To recreate the issue you will need the FPGA AI Suite version 2026.1.1-quartus.
Transfer the the bin and xml files called "fpga_model_spatial_1" to the docker env.
Then execute the following command:
dla_create_ip \
--ip-dir ./ip_repo \
--flow create-ip \
--arch /opt/altera/fpga_ai_suite/ubuntu/dla/example_architectures/AGX5_Simple_Spatial.arch \
--model ./fpga_model_spatial_1.xml
Now in Quartus Prime Pro 26.1, create a now project called "spatial_first". Targeting Agilex5 device A5EB013BB23BE4SR1. Then move the ip_repo folder next to the quartus folder.
Now you will need 4 files,
The Top entity called "spatial_first.vhd"
The QSF config called "spatial_first.qsf"
The system containing the AI model from the ip repo "spatial.qsys"
The signaltaptest.stp to see the signal tap output
The files I have uploaded here on my github, I can also upload the entire project if you will accept that.
https://github.com/madskost/spatial_first
