liny
4 years agoagilex compiles fim error on n6000
hello
I am using n6000 for accelerated development. According to the provided documentation, I compile a fim that can be used for pr, but after deploying the environment, run the command ...
- 4 years ago
The problem has been solved, reinstalling the documentation requires the fim to be down and the quartus to be installed. It may be caused by the mismatch between fim and quartus
thankyou
JohnT_Altera
4 years agoHi,
May I know which Intel OFS FIM version are you using? Can you provide the flow that you are using to compile the design? I suspect that your library is missing some of the IP which cause the error.
