S_J_S
1 year agoAgilex 5 Precision DSP block simulations
Hi, I'm using the Precision DSP blocks in my Agilex 5 design; i have a floating point Add (FP_Add_native_DSP) and a floating point MAC (FP_MAC_native_DSP), but when i try and run simulations with th...
- 1 year ago
Thank you for looking into this further.
I agree the Adder is correct and i've also now seen correct behavior, so i'm not sure why it appeared incorrect previously.
Regarding the MAC; i still see an issue and there has now been an IPS case opened for it (via our AE).
Since there is an IPS case open i'm happy to mark this particular query as closed.
Thank you again for your support,
Simon
CheepinC_altera
1 year agoHi Simon,
Would you be able to share simple simulation examples that replicates the behavior you observed? This would greatly help in my debugging efforts.
If possible, it would also be beneficial to have a reference simulation that passes on Arria 10, so I can use it for comparison and analysis.
Thank you in advance for your support.
Chee Pin
